pycuda: Missing libdevice file for compute_30.
my setup is as follows:
hardware: x86_64, GeForce GTX 650
software: CentOS 7, kernel 3.10.0-693.2.2
I installed nvidia drivers and cudatoolkit 9.0 from nvidia web site, then installed pycuda and numba over python3.4. Installation path is /usr/local/cuda/nvvm
While evaluating a python program, I get
RuntimeError: Missing libdevice file for compute_30.
Please ensure you have package cudatoolkit 7.5.
Install package by:
conda install cudatoolkit=7.5
It seems the driver is searching for a file with name libcompute30.bc; the only installed file is /usr/local/cuda/nvvm/libdevice/libdevice.10.bc
Did something fail during the isntallation ? Is there some way to get rebuild the missing drivers ?
Regards
Pascal
I have the same issue when I try to use the @vectorize decorator.
Did you ever get a resolution, Pascal?
Thanks, John.
you installed CUDA 9 but your numba and/or pycuda install are expecting CUDA toolkit 7.5
Yeah, thats it alright!
I am using the NVidia CUDA AMI: AWS Marketplace: NVIDIA CUDA Toolkit 7.5 on Amazon Linux
Not sure how 9.0 got on there but I think it was pre-installed with the instance. When I went to downgrade to 7.5, ran into package problems.
Solution was to uninstall Anaconda completely, reinstall it and then install the toolkit explicitly choosing version 7.5
