Description
Pyds.get_nvds_buf_surface segmenation fault & Fail to configure caps
Environment
TensorRT Version: tensorrt 7.2.3
GPU Type: GTX 1050ti
Nvidia Driver Version: 465.27
CUDA Version: 10.2
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): python 3.6.
Deepstream Version: 5.0
Issue
When I call get_nvds_buf_surface with my python code, I got Segmentation fault (core dumped)
I think pipeline is right cause I tested on Jetson board.
Here is my pipeline
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
TILED_OUTPUT_WIDTH = 1920
TILED_OUTPUT_HEIGHT = 1080
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 1
def make_pipeline_components(args, number_sources, batch_size):
pipeline_components = dict()
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
else:
streammux.set_property('width', MUXER_OUTPUT_WIDTH) # 1920)
streammux.set_property('height', MUXER_OUTPUT_HEIGHT) # 1080)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
# if is_live:
# print("Atleast one of the sources is live")
# streammux.set_property('live-source', 1)
pipeline_components['streammux'] = streammux
# make pgie component
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
else:
pgie.set_property('config-file-path', "config/pgie_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
#pgie.set_property('model-engine-file', f'model/yangsan.etlt_b{batch_size}_gpu0_fp16.engine')
if pgie_batch_size != number_sources:
print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
number_sources, " \n")
pgie.set_property("batch-size", number_sources)
pipeline_components['pgie'] = pgie
print("Creating Tracker \n ")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
else:
config = configparser.ConfigParser()
config.read('config/tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width':
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height':
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id':
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file':
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file':
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process':
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
pipeline_components['tracker'] = tracker
nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
filter1.set_property("caps", caps1)
pipeline_components['n1'] = nvvidconv1
pipeline_components['f1'] = filter1
# make tiler component
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
else:
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
pipeline_components['tiler'] = tiler
# make nvvidconv component
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
else:
pipeline_components['nvvidconv'] = nvvidconv
# make nvosd component
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
else:
nvosd.set_property('process-mode', OSD_PROCESS_MODE)
nvosd.set_property('display-text', OSD_DISPLAY_TEXT)
pipeline_components['nvosd'] = nvosd
if args.port is not None:
# codec = "H264"
bitrate = 4000000
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
pipeline_components['nvvidconv_postosd'] = nvvidconv_postosd
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
pipeline_components['caps'] = caps
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
print("Creating H264 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property('bitrate', bitrate)
if is_aarch64():
encoder.set_property('preset-level', 1)
encoder.set_property('insert-sps-pps', 1)
encoder.set_property('bufapi-version', 1)
pipeline_components['encoder'] = encoder
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
pipeline_components['rtppay'] = rtppay
if is_aarch64():
# make transform component
print("Creating transform \n ")
transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
if not transform:
sys.stderr.write(" Unable to create transform \n")
else:
pipeline_components['transform'] = transform
# Make the UDP sink
updsink_port_num = args.port
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property('host', '224.224.255.255')
sink.set_property('port', updsink_port_num)
sink.set_property('async', False)
sink.set_property('sync', 0)
sink.set_property("qos", 0)
pipeline_components['sink'] = sink
print("Creating Analytics - line crossing")
analytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
if not analytics:
sys.stderr.write(" Unable to create analytics \n")
else:
analytics.set_property('config-file', args.analytics)
pipeline_components['analytics'] = analytics
return pipeline_components
def make_pipeline(args, pipeline_components, number_sources, input_source):
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
pipeline.add(pipeline_components['streammux'])
# source pipeline
for i in range(number_sources):
print("Creating source_bin ", i, " \n ")
uri_name = input_source[i]
# if uri_name.find("rtsp://") == 0:
# is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = pipeline_components['streammux'].get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
print("Adding elements to Pipeline \n")
pipeline.add(pipeline_components['pgie'])
pipeline.add(pipeline_components['tracker'])
pipeline.add(pipeline_components['analytics'])
pipeline.add(pipeline_components['n1'])
pipeline.add(pipeline_components['f1'])
pipeline.add(pipeline_components['tiler'])
pipeline.add(pipeline_components['nvvidconv'])
pipeline.add(pipeline_components['nvosd'])
pipeline.add(pipeline_components['nvvidconv_postosd'])
pipeline.add(pipeline_components['caps'])
pipeline.add(pipeline_components['encoder'])
pipeline.add(pipeline_components['rtppay'])
if is_aarch64():
pipeline.add(pipeline_components['transform'])
pipeline.add(pipeline_components['sink'])
return pipeline
def link_components(args, pipeline_components):
print("Linking elements in the Pipeline \n")
pipeline_components['streammux'].link(pipeline_components['pgie'])
pipeline_components['pgie'].link(pipeline_components['tracker'])
pipeline_components['tracker'].link(pipeline_components['n1'])
pipeline_components['n1'].link(pipeline_components['f1'])
pipeline_components['f1'].link(pipeline_components['analytics'])
pipeline_components['analytics'].link(pipeline_components['tiler'])
pipeline_components['tiler'].link(pipeline_components['nvvidconv'])
pipeline_components['nvvidconv'].link(pipeline_components['nvosd'])
pipeline_components['nvosd'].link(pipeline_components['nvvidconv_postosd'])
pipeline_components['nvvidconv_postosd'].link(pipeline_components['caps'])
pipeline_components['caps'].link(pipeline_components['encoder'])
pipeline_components['encoder'].link(pipeline_components['rtppay'])
pipeline_components['rtppay'].link(pipeline_components['sink'])
I’m trying to inference on NGC ds-5.0 container for dgpu (tag-5.0.1-20.09-base)
Also, Video doesn’t display anything.
Here is my GST_DEBUG=3 error script
Creating Pgie
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
Creating Tracker
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
['adult', 'child']
Now playing...
0 : file:///workspace/its-final/daycare2.mp4
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvDCF] Initialized
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:01.337936877 5392 0xc3b84f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/workspace/its-final/model/yangsan.etlt_b1_gpu0_fp32.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 8x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 2x34x60
0:00:01.338012528 5392 0xc3b84f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /workspace/its-final/model/yangsan.etlt_b1_gpu0_fp32.engine
0:00:01.338882939 5392 0xc3b84f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:config/pgie_config.txt sucessfully
Decodebin child added: urisourcebin0
0:00:01.340004639 5392 0xc3b84f0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
0:00:01.340174012 5392 0xc3b84f0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
0:00:01.344189070 5392 0x7f58780505e0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type pasp
0:00:01.344207680 5392 0x7f58780505e0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:01.344215490 5392 0x7f58780505e0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:01.344221109 5392 0x7f58780505e0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type keys
0:00:01.344226083 5392 0x7f58780505e0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type ....
0:00:01.344237756 5392 0x7f58780505e0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:01.344274070 5392 0x7f58780505e0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:01.345534476 5392 0x7f58780505e0 FIXME decodebin3 gstdecodebin3.c:1098:update_requested_selection:<decodebin3-0> Implement EXPOSE_ALL_MODE
0:00:01.346261108 5392 0x7f58780505e0 FIXME decodebin3 gstdecodebin3-parse.c:420:parsebin_buffer_probe:<decodebin3-0> Re-use existing input streams if/when possible
0:00:01.346474594 5392 0x7f5878057e80 FIXME decodebin3 gstdecodebin3.c:1450:get_output_for_slot:<decodebin3-0> emit autoplug-continue
0:00:01.346490081 5392 0x7f5878057e80 FIXME decodebin3 gstdecodebin3.c:1453:get_output_for_slot:<decodebin3-0> Handle EXPOSE_ALL_MODE
In cb_newpad
video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:01.348362658 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348374648 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:01.348380264 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348385054 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:01.348414076 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348435276 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:01.348442623 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348463225 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:01.348474004 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348478884 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:01.348487101 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348495061 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:01.348513249 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348521896 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:01.348527457 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.348535564 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:01.348771168 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:01.348780970 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:01.348786774 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:01.348795512 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:01.348807053 5392 0x7f5878057e80 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f5870010c50 Failed to determine interlace mode
0:00:01.348889803 5392 0x7f5878057de0 FIXME decodebin3 gstdecodebin3.c:1450:get_output_for_slot:<decodebin3-0> emit autoplug-continue
0:00:01.348915372 5392 0x7f5878057de0 FIXME decodebin3 gstdecodebin3.c:1453:get_output_for_slot:<decodebin3-0> Handle EXPOSE_ALL_MODE
In cb_newpad
audio/x-raw, layout=(string)interleaved, format=(string)F32LE
0:00:01.477570339 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.477663126 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.477769888 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.477798621 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.477895257 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.477935599 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478030313 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478056919 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478139761 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478184755 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478275657 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.478302765 5392 0x7f5878057e80 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
0:00:01.599539127 5392 0x3235000 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2784:gst_eglglessink_configure_caps:<nvvideo-renderer> Cuda Init failed
0:00:01.599550928 5392 0x3235000 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2795:gst_eglglessink_configure_caps:<nvvideo-renderer> Configuring caps failed
0:00:01.599597273 5392 0x7f5878057e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.599649779 5392 0x7f5878057e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.599657083 5392 0x7f5878057e80 WARN GST_PADS gstpad.c:4226:gst_pad_peer_query:<onscreendisplay:src> could not send sticky events
0:00:01.600570133 5392 0x7f5878057e80 WARN v4l2videodec gstv4l2videodec.c:1614:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:01.600600524 5392 0x7f5878057e80 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:01.600807432 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.600994738 5392 0x7f5870021a30 WARN v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:01.601123774 5392 0x7f5870021a30 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601149402 5392 0x7f5870021a30 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601172751 5392 0x7f5870021a30 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601242332 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601258790 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601267289 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601344682 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601359348 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.601366274 5392 0x7f5870021850 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.769412728 5392 0x3234e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.774342712 5392 0x3234e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.779613618 5392 0x3234e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.799766918 5392 0x3234e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:00:01.814857378 5392 0x3234e80 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
Segmentation fault (core dumped) <- At This time called pyds.get_nvds_buf_surface()
