• Hardware Platform (Jetson / GPU) P4
• DeepStream Version 5.1
• TensorRT Version7
• NVIDIA GPU Driver Version (valid for GPU only) 11.1
Inside docker:
docker run -it --rm --gpus all -v /root/data/workspace/python:/opt/nvidia/deepstream/deepstream-5.1/sources/python nvcr.io/nvidia/deepstream:5.1-21.02-triton-updated-03
Running test similar to Test4, but always get error
Frame Number = 26 Vehicle Count = 2 Person Count = 1
Frame Number = 27 Vehicle Count = 2 Person Count = 1
Frame Number = 28 Vehicle Count = 2 Person Count = 1
Frame Number = 29 Vehicle Count = 2 Person Count = 1
Frame Number = 30 Vehicle Count = 2 Person Count = 1
Frame Number = 31 Vehicle Count = 2 Person Count = 1
terminate called after throwing an instance of ‘std::bad_function_call’
what(): bad_function_call
I managed to narrow down the cause as the title suggest, when I comment below 2 lines of code, it works well.
pyds.user_copyfunc(user_event_meta, meta_copy_func)
pyds.user_releasefunc(user_event_meta, meta_free_func)
cfg_amqp.txt (1.3 KB)
deepstream_test_0.py (29.3 KB)
dstest1_pgie_config.txt (3.4 KB)
msgconv_config.txt (1.9 KB)
test_0_tracker_config.txt (1.8 KB)
tracker_config.yml (6.5 KB)
