On some files PyNvVideoCodec SimpleDecoder crashes. No error output at all. In the below example directly, for other video files at some frame. Most video files work fine.
The worst thing is that there seems no way to catch this error with python.
OS: Windows 10 Enterprise 22H2
PyNvVideoCodec Version: 2.1.0
Driver: 32.0.15.7700 (I have issues updating due to corperate policies)
link to video: https://www.pexels.com/video/a-subway-train-is-stopped-at-a-station-18553046/
code:
import os
import PyNvVideoCodec as nvc
video_path = “18553046-uhd_3840_2160_30fps.mp4”
os.environ[“LOGGER_LEVEL”] = “DEBUG”
decoder = nvc.SimpleDecoder(
video_path, gpu_id=0, output_color_type=nvc.OutputColorType.RGBP, need_scanned_stream_metadata=True,)
print(“loaded”)
output:
[h264 @ 000002A333EAF500] no picture
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A334142100] demuxer injecting skip 2048 / discard 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A334142100] All info found
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A334142100] After avformat_find_stream_info() pos: 2303960 bytes read:2336223 seeks:0 frames:16
[AVFormatContext @ 000002A33416C580] Opening ‘18553046-uhd_3840_2160_30fps.mp4’ for reading
[file @ 000002A3340D3440] Setting default whitelist ‘file,crypto,data’
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] ISO: File Type Major Brand: mp42
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Unknown dref type 0x206c7275 size 12
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Processing st: 0, edit list 0 - media time: 3003, duration: 941900
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Offset DTS by 3003 to make first pts zero.
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Setting codecpar->delay to 2 for stream st: 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Processing st: 1, edit list 0 - media time: 2048, duration: 1510400
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] drop a frame at curr_cts: 0 @ 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] drop a frame at curr_cts: 1024 @ 1
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] Before avformat_find_stream_info() pos: 19732 bytes read:32768 seeks:0 nb_streams:2
[h264 @ 000002A333EAF500] nal_unit_type: 7(SPS), nal_ref_idc: 3
[h264 @ 000002A333EAF500] Decoding VUI
[h264 @ 000002A333EAF500] nal_unit_type: 8(PPS), nal_ref_idc: 3
[h264 @ 000002A333EAF500] nal_unit_type: 6(SEI), nal_ref_idc: 0
[h264 @ 000002A333EAF500] nal_unit_type: 5(IDR), nal_ref_idc: 3
[h264 @ 000002A333EAF500] Format yuv420p chosen by get_format().
[h264 @ 000002A333EAF500] Reinit context to 3840x2160, pix_fmt: yuv420p
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] demuxer injecting skip 2048 / discard 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] All info found
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002A33416C580] After avformat_find_stream_info() pos: 2303960 bytes read:2336223 seeks:0 frames:16
[AVIOContext @ 000002A33403AA80] Statistics: 98758271 bytes read, 0 seeks
[h264 @ 000002A333EAFC40] nal_unit_type: 7(SPS), nal_ref_idc: 3
[h264 @ 000002A333EAFC40] Decoding VUI
[h264 @ 000002A333EAFC40] nal_unit_type: 8(PPS), nal_ref_idc: 3
