I am running the following versions, trying to install torch and torchvision
Jetpack --version 6.2
Ubuntu --version 22.04
CUDA --version 12.6
I followed the instruction here , and installing using
wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/6ef/f643c0a7acda9/torch-2.7.0-cp310-cp310-linux_aarch64.whl#sha256=6eff643c0a7acda92734cc798338f733ff35c7df1a4434576f5ff7c66fc97319
wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/daa/bff3a07259968/torchvision-0.22.0-cp310-cp310-linux_aarch64.whl#sha256=daabff3a0725996886b92e4b5dd143f5750ef4b181b5c7d01371a9185e8f0402
However, we got the error wget: unable to resolve host address ‘pypi.jetson-ai-lab.dev’. Moreover, I can’t get the appropriate torch and torchvision distributions from the `https://developer.download.nvidia.com/compute/redist/jp/v61/pytorch/torch-2.5.0a0+872d972e41.nv24.08.17622132-cp310-cp310-linux_aarch64.whl\`path .
How do we download the appropriate distribution.
Please find the apt server below:
We have updated the PyTorch and TorchVision version to 2.8.0 and 0.26.0.
Hi, I tried downloading torch-2.11.0 from the provided link but it is not compatible with my Jetson platform. Only the older version from `https://developer.download.nvidia.com/compute/redist/jp/v61/pytorch/torch-2.5.0a0+872d972e41.nv24.08.17622132-cp310-cp310-linux_aarch64.whl\` runs properly.
Moreover, the Compatibility Matrix also says that Torch 2.11 is only compatible with Jetpack 7
Do you use JetPack 7 with Thor?
If yes, please find the package below:
https://pypi.jetson-ai-lab.io is down… 502 Bad Gateway
Thanks for your help.
We are using Jatpack 6.2 w/ Orin nano
Hi, all
We are checking this issue with our internal team.
If you are looking for PyTorch on JetPack 6, please check if the packages mentioned in the link below:
Hi all,
We are checking this issue internally.
For PyTorch, you can download from the link below instead:
The server is back. Please check it again.
Thanks and sorry for the inconvenience.
