Python_apps can't run
I’am use “python3 deepstream_test_1.py /home/optical/deepstream_sdk_v4.0.1_x86_64/samples/streams/sample_1080p_h264.mp4” to run this example ,but it still stop in this step:
optical@optical-X10DRi:~/deepstream_sdk_v4.0.1_x86_64/sources/python/apps/deepstream-test1$ python3 deepstream_test_1.py /home/optical/deepstream_sdk_v4.0.1_x86_64/samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /home/optical/deepstream_sdk_v4.0.1_x86_64/samples/streams/sample_1080p_h264.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Creating LL OSD context new
0:00:00.450150560 42571 0xd219d20 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.734799314 42571 0xd219d20 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.691265624 42571 0xd219d20 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.747262659 42571 0xd219d20 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/optical/deepstream_sdk_v4.0.1_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
0:00:10.753223668 42571 0xd219d20 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.756572263 42571 0xd219d20 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
it is keep this status,and i can,t use CTRL+C to quit it.What should I do?Thanks.
How long did you wait? Seems TensorRT in DeepStream was building the TensorRT engine, it needs take several minutes. Have you waited so long time?
Hi,I waited a little longer,it continue run.Thanks for your help!!!
