Python bindings for Smart Video Record
Is there any python bindings for smart record now?
As per statement ( there is only C version smart-record , you can try valve + “encoder+mux+filesink” to implement, please refer to deepstream-python )in here
Would it be possible to get it working for multiple stream sources with a greater speed?
no, it is still on the roadmap.
can you elaborate on this?
I mean, would we be able to achieve the same performance observed when we use the smart capture functionality?
please refer to smart recording design doc. it is used to accpet rtsp source because there is no transcode in recordbin. if there is encoding in the custom recordbin, there should be a different performance. As you know, encoding will use resource and cause delay.
