Python DeepStream program not generating dot file
T4
• DeepStream Version
5.0
NA
• TensorRT Version
7.0.0.11
440.64.00
I am trying to run deepstream_test_3.py.
export GST_DEBUG_DUMP_DOT_DIR=/tmp/
python3 deepstream_test_3.py input.h264
This is not generating the dot files to /tmp/. Graphviz is installed.
os.environ["GST_DEBUG_DUMP_DOT_DIR"] = "/tmp"
os.putenv('GST_DEBUG_DUMP_DIR_DIR', '/tmp')
I tried adding the above code into the test python program. But still the dot files are not getting generated.
I also tried installing graphviz-dev apt package and the pygraphviz pip package. Still no dot files are getting generated.
In c++ sample, it needs to call “GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS(GST_BIN(gst_objs.pipeline), GST_DEBUG_GRAPH_SHOW_ALL, “demo-app-pipeline”);” to enable the dot file output.
I think you need to call the equivalent GST python API
I think GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS is a C macro and cannot be directly used in python.
that’s why I said the equivalent GST python API, please note!
In python it’s:
Gst.debug_bin_to_dot_file(pipeline, Gst.DebugGraphDetails.ALL, filename)
Good to know, thanks @nors
Thanks ! It worked. Just for reference below are the things I did.
As early in the program as possible, add the following:-
Once the graph is fully created and just before triggering the main loop do the following:
Gst.debug_bin_to_dot_file(pipeline, Gst.DebugGraphDetails.ALL, "pipeline")
This creates /tmp/pipeline.dot when the program is run.
