Python Deepstream test-4 kafka error
• Hardware Platform (Jetson / GPU) H100
• DeepStream Version 6.4
• TensorRT Version
Hi, I am running the python deepstream test4 to test out on the message broker feature on deepstream. However, it outputs below error:
e> error: streaming stopped, reason not-negotiated (-4)
Frame Number = 2 Vehicle Count = 9 Person Count = 1
Frame Number = 3 Vehicle Count = 9 Person Count = 2
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2406): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
%3|1719559328.003|ERROR|rdkafka#producer-1| [thrd:app]: rdkafka#producer-1: localhost:9092/bootstrap: ApiVersionRequest failed: Local: Timed out: probably due to broker version < 0.10 (see api.version.request configuration) (after 10010ms in state APIVERSION_QUERY)
%3|1719559328.003|ERROR|rdkafka#producer-1| [thrd:app]: rdkafka#producer-1: localhost:9092/bootstrap: ApiVersionRequest failed: Local: Timed out: probably due to broker version < 0.10 (see api.version.request configuration) (after 10010ms in state APIVERSION_QUERY, 1 identical error(s) suppressed)
%3|1719559328.003|ERROR|rdkafka#producer-1| [thrd:app]: rdkafka#producer-1: localhost:9092/bootstrap: ApiVersionRequest failed: Local: Timed out: probably due to broker version < 0.10 (see api.version.request configuration) (after 10009ms in state APIVERSION_QUERY, 3 identical error(s) suppressed)
nvstreammux: Successfully handled EOS for source_id=0
I am using the kbzimage/wurstmeister-zookeeper for zookeeper and apache/kafka for messagebroker in the docker container. Any advice on why is it producing this error?
it is related to the kafka server settings. please refer to this topic.
When it mentioned about “kafka server.properties”, may i know where can i find the config file to change the settings in it?
DeepStream kafka client is opensource. please refer to /opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor/.
as for the kafka server, using kafka kafka_2.13-3.3.1.tgz, I can’t reproduce this issue. Here is kafka server setting method.
