• Hardware Platform(GPU)
• DeepStream Version 5.0
• NVIDIA GPU Driver Version (440.64)
When rtsp sample provided with 5.0 SDK is executed as below, no RTSP stream is generated and Warnings are noticed with GST_DEBUG=2.
/opt/nvidia/deepstream/deepstream-5.0/sources/python/apps/deepstream-test1-rtsp-out# python3 deepstream_test1_rtsp_out.py -i …/…/…/…/samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating H264 Encoder
Creating H264 rtppay
Playing file …/…/…/…/samples/streams/sample_1080p_h264.mp4
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Adding elements to Pipeline
Linking elements in the Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Starting pipeline
0:00:00.049295786 99 0x1fbfd80 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.049308610 99 0x1fbfd80 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat YM12
0:00:01.283839821 99 0x17e7590 WARN codecparsers_h264 gsth264parser.c:1550:gst_h264_parse_sps_data: failed to read UE
0:00:01.283844851 99 0x17e7590 WARN codecparsers_h264 gsth264parser.c:1768:gst_h264_parse_sps: error parsing “Sequence parameter set”
0:00:01.283849660 99 0x17e7590 WARN h264parse gsth264parse.c:739:gst_h264_parse_process_nal: failed to parse SPS:
0:00:01.283855350 99 0x17e7590 WARN h264parse gsth264parse.c:1237:gst_h264_parse_handle_frame: broken/invalid nal Type: 7 SPS, Size: 5 will be dropped
0:00:01.283931484 99 0x17e7590 WARN h264parse gsth264parse.c:1237:gst_h264_parse_handle_frame: broken/invalid nal Type: 0 Unknown, Size: 38363 will be dropped
It is not clear what is going on beyond this.
No further logs are displayed and the application waits permanently.
Any suggestions as to how to go about this issues?
