Python scripting stops working after some time
After applying the python scripting to a prim, it works in the beginning, but after some time it stops working and I get the error like below. I have to quit the app and relaunch again for it to work, and then the same problem happens again. Can you help to check? I’m using Create 2022.3.3
2023-04-09 12:39:53  [Error] [carb.events.python] OSError: [Errno 22] Invalid argument
2023-04-09 12:39:53  [Error] [carb.events.python] At:
2023-04-09 12:39:53  [Error] [carb.events.python]   d:/ov/library/create-2022.3.3/kit/kernel/py\omni\kit\app\_impl\__init__.py(137): write
2023-04-09 12:39:53  [Error] [carb.events.python]   D:\ov\tutorials\code\Hover\Hover.py(17): on_play
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\extscache\omni.kit.scripting-104.2.2+104.2.wx64.r.cp37\omni\kit\scripting\scripts\script_manager.py(111): <lambda>
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\extscache\omni.kit.scripting-104.2.2+104.2.wx64.r.cp37\omni\kit\scripting\scripts\script_manager.py(354): _foreach_script_instance
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\extscache\omni.kit.scripting-104.2.2+104.2.wx64.r.cp37\omni\kit\scripting\scripts\script_manager.py(111): _on_timeline_event
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\kit\exts\omni.kit.widget.toolbar\omni\kit\widget\toolbar\commands.py(19): do
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\kit\extscore\omni.kit.commands\omni\kit\undo\undo.py(80): execute
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\kit\extscore\omni.kit.commands\omni\kit\commands\command.py(459): execute
2023-04-09 12:39:53  [Error] [carb.events.python]   d:\ov\library\create-2022.3.3\kit\exts\omni.kit.widget.toolbar\omni\kit\widget\toolbar\builtin_tools\models\timeline_model.py(37): set_value
Hi @qazs. This is a known issue when you use print directly. You can find the workaround and internal issue number here: Calling on_update gives OSError:Errno22 Invalid argument - #4 by mati-nvidia
Keep an eye on the Kit Release Notes for the issue number to know when it’s been fixed.
