More context, it happens after the first kit.update()
call. Here’s my REPL session:
>>> from isaacsim import SimulationApp
>>> kit = SimulationApp({"headless": True})
>>> from omni.isaac.core.utils.extensions import enable_extension
>>> enable_extension("omni.isaac.ros2_bridge")
>>> import omni
>>> usd_path = "/isaac-sim/workspaces/blank.usd"
>>> omni.usd.get_context().open_stage(usd_path)
True
>>> kit.update()
Fatal Python error: Segmentation fault
Thread 0x00007f21417fc640 (most recent call first):
File "/isaac-sim/kit/python/lib/python3.10/concurrent/futures/thread.py", line 81 in _worker
File "/isaac-sim/kit/python/lib/python3.10/threading.py", line 953 in run
File "/isaac-sim/kit/python/lib/python3.10/threading.py", line 1016 in _bootstrap_inner
File "/isaac-sim/kit/python/lib/python3.10/threading.py", line 973 in _bootstrap
Thread 0x00007f2f3effd640 (most recent call first):
Thread 0x00007f2f5dfff640 (most recent call first):
Thread 0x00007f2f5d7fe640 (most recent call first):
Thread 0x00007f2f5fff8640 (most recent call first):
Thread 0x00007f313f0f1b80 (most recent call first):
File "/isaac-sim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py", line 504 in update
File "<stdin>", line 1 in <module>
Extension modules: psutil._psutil_linux, psutil._psutil_posix, omni.mdl.pymdlsdk._pymdlsdk, numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, PIL._imaging, PIL._imagingft, scipy._lib._ccallback_c, scipy.ndimage._nd_image, scipy.special._ufuncs_cxx, scipy.special._ufuncs, scipy.special._specfun, scipy.special._comb, scipy.linalg._fblas, scipy.linalg._flapack, scipy.linalg._cythonized_array_utils, scipy.linalg._flinalg, scipy.linalg._solve_toeplitz, scipy.linalg._matfuncs_sqrtm_triu, scipy.linalg.cython_lapack, scipy.linalg.cython_blas, scipy.linalg._matfuncs_expm, scipy.linalg._decomp_update, scipy.sparse._sparsetools, _csparsetools, scipy.sparse._csparsetools, scipy.sparse.linalg._isolve._iterative, scipy.sparse.linalg._dsolve._superlu, scipy.sparse.linalg._eigen.arpack._arpack, scipy.sparse.csgraph._tools, scipy.sparse.csgraph._shortest_path, scipy.sparse.csgraph._traversal, scipy.sparse.csgraph._min_spanning_tree, scipy.sparse.csgraph._flow, scipy.sparse.csgraph._matching, scipy.sparse.csgraph._reordering, scipy.special._ellip_harm_2, _ni_label, scipy.ndimage._ni_label, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special, scipy.spatial._ckdtree, scipy._lib.messagestream, scipy.spatial._qhull, scipy.spatial._voronoi, scipy.spatial._distance_wrap, scipy.spatial._hausdorff, scipy.spatial.transform._rotation, osqp._osqp, multidict._multidict, yarl._quoting_c, aiohttp._helpers, aiohttp._http_writer, aiohttp._http_parser, aiohttp._websocket, _cffi_backend, frozenlist._frozenlist, scipy.io.matlab._mio_utils, scipy.io.matlab._streams, scipy.io.matlab._mio5_utils, yaml._yaml, cv2 (total: 78)
./python.sh: line 41: 24398 Segmentation fault (core dumped) $python_exe "$@" $args
There was an error running python
If I take away enabling the ros2 bridge extension, it works just fine.
And I’m running the python.sh file from a terminal that has sourced ROS2.
