I have a very simple python script that sets up a udp socket and reads a single packet in. I have this script running in windows but when I try to test on my orin board no packets are shown in python. I connect to a udp packet generator through ethernet then set the static IP for the ethernet port. I am able to ping the IP and I can bind to the port in python but it shows that there are no packets coming through. I also have wireshark running and I can verify that UDP packets are being sent to that IP & Port. I’m not sure how to troubleshoot this.
hi soph44lea
This a Orin issue, could you please kindly recreate a new topic to DRIVE AGX Orin - NVIDIA Developer Forums
Thank you
Meng, Shi
