Can I use Python to communicate with the TX2
What kind of communication do you want to achieve?
You can write python code on TX2 and the network is functional.
Like can I run my Python scripts on it.
Yes, absolutely.
Once you’ve logged into your machine, you can find details about your Python setup:
$ python --version
This will tell you the current default python version that your TX2 has
$ which python
This will tell you where the default python version resides (usually /usr/bin/python)
If i’m not mistaken, I think JetPack also includes iPython (https://ipython.org/) So you can use an interactive python shell if you desire.
$ ipython
