Hello!
Like a previous user, I am trying to get my code running correctly using CUDA on my Jetson AGX Orin.
I am running into the same error with torchvision:
RuntimeError: operator torchvision::nms does not exist
To reproduce the error, I just need to run code that imports torchvision:
import torch
import torchvision
Per the last discussion on this topic, this error results from incompatible PyTorch and Torchvision installations. Hence, I have reinstalled the two libraries multiple times in different ways, failing in different ways each time (like a previous user):
Normal pip/pip3 install — pip3 defaults to cpu binaries for the packages, resulting in my code returning False for torch.cuda.is_available()
Install torch as instructed here, from https://developer.download.nvidia.com/compute/redist/jp/v61/pytorch/torch-2.5.0a0+872d972e41.nv24.08.17622132-cp310-cp310-linux_aarch64.whl — results in torch and torchvision version discrepancy, BUT torch.cuda.is_available() returns True.
Install torch and torchvision via jetson-containers — this results in the ‘nms does not exist’ error shown above.
Some information about my system:
Currently, it is running JetPack 6.2.1 with torch version “2.5.0a0+872d972e41.nv24.08.17622132-cp310-cp310-linux_aarch64” and torchvision version 0.20.0.
I would appreciate any help with this.
P.S. all the previous links to http://jetson.webredirect.org in the previous topics are dead
