Hi @alireza.rf, the JetPack 4.4 production release (L4T R32.4.3) only supports PyTorch 1.6.0 (and newer), because cuDNN had removed some previously-deprecated functions that required PyTorch to be updated. The same goes for JetPack 4.4.1 (L4T R32.4.4) - it needs PyTorch 1.6.0 or newer.
Iâm using virtual environment(miniforge) on jetson xavier nx.
I have met following error.
(yolov5_env) hodu@hodu-desktop:~$ pip3 install numpy torch-1.7.0-cp36-cp36m-linux_aarch64.whl
ERROR: torch-1.7.0-cp36-cp36m-linux_aarch64.whl is not a supported wheel on this platform.
What am I supposed to do?
Thank you.
Hi @forumuser, is hodu-desktop
machine your Jetson, or is it a PC?
If you are indeed logged into your Jetson, can you confirm first that youâre able to install the wheel successfully outside of virtualenv?
hodu-desktop is a Jetson
I can install the wheel successfully outside of virtualenv.
Thank you.
Hmm ok - I havenât used virtualenv myself before (instead I use containers), but I believe others on this thread have been able to. Can you check pip3 --version
or python3 --version
from within your virtualenv to confirm that itâs indeed a Python 3.6 environment?
When I make virtualenv, I guess I specify python version3.7.
sooner or later, let me know you.
Thank you.
OK thanks, yea it would need to be created as a Python 3.6 environment to work with those wheels.
hi,I created a python 3.6 environment with miniforge-pypypy3, in which Python 3.6 - torch-1.6.0-cp36-cp36m-linux was installed_ Aarch64.whl, then encountered a problem installing pytorch v1.6 - torch vision v0.7.0,
~/torchvision$ sudo python3 setup.py install
File âsetup.pyâ, line 13, in
import torch
ModuleNotFoundError: No module named âtorchâ
but I already have Python installed and can import it
~/torchvision$ python
Python 3.6.11 | packaged by conda-forge | (default, Nov 27 2020, 18:40:28)
[GCC 9.3.0] on linux
Type âhelpâ, âcopyrightâ, âcreditsâ or âlicenseâ for more information.import torch
print(torch.version)
1.6.0
How can I solve itïŒthanks
Hi @1754387338, I havenât used miniforge before, but it would appear that torchvision through python3 isnât able to find the torch package you installed. If you run python3
are you able to import torch
If not, you might want to symbolically link python3
to python
so that the torchvision install script can find it.
hi,
I tried to use:
pip3 install torch-1.4.0-cp36-cp36m-linux_aarch64.whl
And
pip3 install torch-1.7.0-cp36-cp36m-linux_aarch64.whl
I have downloaded the two whl files. But every time it went wrong.
The error is displayed as follows:
Defaulting to user installation because normal site-packages is not writeable
ERROR: torch-1.6.0-cp36-cp36m-linux_aarch64.whl is not a supported wheel on this platform.
In addition, I am using python3.8, because I want to deploy yolov5 on jetson nano, which requires python3.8
Why donât these containers include OpenCV yet? Seriously whatâs the point of this. Your docker system is so useless Iâve spent a week on headaches of missling libraries that should have been included by default. All these dumb methods to pipe over libraries from my main os⊠Does anyone who actually do ML work make these?
Hi @industrialacc0, we try to keep the size down on the l4t-pytorch and l4t-tensorflow containers by not installing extra libraries into those. You can use these base containers as a starting point and create your own containers from them (e.g. via Dockerfiles)
You can see the Dockerfile commands for installing the version of OpenCV that comes with JetPack here, so you neednât mount it from the host if you donât want to:
You can also change/rebuild these base containers yourself, as the base Dockerfiles and build scripts for the containers are open-sourced here:
https://github.com/dusty-nv/jetson-containers
And yes, I do a lot of ML work in PyTorch but have not needed OpenCV as a frequent dependency, and it is a large library. Iâll consider adding it to the larger l4t-ml container, but perhaps folks may desire their own customized/newer version of OpenCV, which having a pre-existing version could complicate the install of.
Hi @zlbzailushang, these PyTorch wheels were built for Python 3.6, so they wouldnât work on Python 3.8. However some other users on this topic and in the forums have been able to rebuild PyTorch for Python 3.8. Please see this post for more info:
thanks a lot.
need VPN to use wget to download
Thanks I was very frustrated when I wrote this I didnât expect a useful solution so I just built OpenCV from scratch before. Your solution will probably work a lot better. In another topic your colleague recommended to change csv files and stuff
On a sidenote, I would expect most people to use the Jetsons for Machine vision inference devices (at least I do). Having pure ML containers without the libraries most commonly used in combination with them such as seems like a bit of a waste but thatâs up to you guys I guess.
In any case thank you!
@industrialacc0 thanks for your feedback and following up. In the next version of the l4t-ml container, I have added OpenCV 4.4.1 to it (the one that comes with JetPack). l4t-ml is the big container with PyTorch/TensorFlow/JupyterLab/scipy/sklearn/ect, so that can provide users a good starting point.
@dusty_nv , something seems wrong with the prebuilt PyTorch v1.7.0. To reproduce on AGX Xavier:
Letâs start with the official Docker image:
docker run --rm -it --gpus all nvcr.io/nvidia/l4t-pytorch:r32.4.4-pth1.6-py3
Now, inside the Docker container, we do:
wget https://nvidia.box.com/shared/static/wa34qwrwtk9njtyarwt5nvo6imenfy26.whl -O torch-1.7.0-cp36-cp36m-linux_aarch64.whl
python3
import torch
import torch.nn.functional as F
x = torch.tensor([12.345])
print(x)
print(F.softmax(x))
The expected results are:
12.345
1.
The actual results are:
12.
nan
The above issue only happens to CPU tensors. If we do x = x.cuda()
before printing, then weâll see the correct results. I suspect something is wrong with the CPU library.
Also, PyTorch v1.6.0 doesnât have the above problem.
Hi @yin, it seems this issue may be related to this PyTorch 1.7.0 issue: https://github.com/pytorch/pytorch/issues/49157
Not sure if it has been addressed in 1.7.1 or not. I donât think it is particular to how I built the wheel. For now, you may want to stick with 1.6.0 or try building the wheel for 1.7.1 to see if that fixes it (although I would expect that to be indicated in the PyTorch issue above at some point)
Thanks for the prompt reply @dusty_nv.
I built v1.7.1 from source following your instructions, and encountered the same issue.
This issue is specific to Jetson. It doesnât happen on the desktop version of PyTorch downloaded from PyTorchâs conda channel.
David
