PyTorch Install problem (Solved)
I ran into the same issue. Turns out that the CUDA toolkit was not installed correctly from Jetpack 4.1.1.
(/usr/local/cuda-10.0 was not installed after reflashing).
On the Xavier, I noticed apt-get was not working, so I did an update
> sudo apt-get update
Relaunch Jetpack 4.1.1, and just reinstall the target modules. Verify Cuda 10 is installed.
Install the pytorch
sudo pip3 install torch-1.0.0a0+8601b33-cp36-cp36m-linux_aarch64.whl
sudo pip3 install torchvision
if all works
python3
import torch
torch.backends.cudnn.is_acceptable(torch.cuda.FloatTensor(1))
How to add cuda10 patch
For what is worth, I’ve reverted to building pytorch from source as the wheel was not built with the settings I needed. I created a fork on github with the changes for the Xavier. By default it builds pytorch with TensorRT backend enabled, and expects OpenBLAS to be installed.
-Rich
Nice! Thanks for sharing!
I ran into the same issue.But my cuda10 was installed .what can I do?
Are you using JetPack 4.2?
Please check this topic for the pyTorch package for the JetPack4.2:
https://devtalk.nvidia.com/default/topic/1049071/pytorch-for-jetson-nano/
Thanks,I did it ,but it showed error:
Processing ./torch-1.1.0a0+b457266-cp36-cp36m-linux_aarch64.whl
ERROR: Exception:
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/cli/base_command.py”, line 178, in main
status = self.run(options, args)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/commands/install.py”, line 352, in run
resolver.resolve(requirement_set)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/resolve.py”, line 131, in resolve
self._resolve_one(requirement_set, req)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/resolve.py”, line 294, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/resolve.py”, line 242, in _get_abstract_dist_for
self.require_hashes
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/operations/prepare.py”, line 353, in prepare_linked_requirement
progress_bar=self.progress_bar
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/download.py”, line 873, in unpack_url
unpack_file_url(link, location, download_dir, hashes=hashes)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/download.py”, line 807, in unpack_file_url
unpack_file(from_path, location, content_type, link)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/utils/misc.py”, line 628, in unpack_file
flatten=not filename.endswith(’.whl’)
File “/home/nvidia/.local/lib/python3.6/site-packages/pip/_internal/utils/misc.py”, line 505, in unzip_file
zip = zipfile.ZipFile(zipfp, allowZip64=True)
File “/usr/lib/python3.6/zipfile.py”, line 1131, in init
self._RealGetContents()
File “/usr/lib/python3.6/zipfile.py”, line 1198, in _RealGetContents
raise BadZipFile(“File is not a zip file”)
zipfile.BadZipFile: File is not a zip file
what can I do?
Please noticed this wheel is for JetPack4.1.1.
If you want the version for JetPack 4.2, please check this topic:
https://devtalk.nvidia.com/default/topic/1049071/jetson-nano/pytorch-for-jetson-nano/
thanks very much! You solved my problem
when I use the whl file in my python3.6, I get the following ERROR:
$sudo pip3 install torch-1.0.0a0+8601b33-cp36-cp36m-linux_aarch64.whl
WARNING: The directory ‘/home/dji/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
WARNING: The directory ‘/home/dji/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Processing ./torch-1.0.0a0+8601b33-cp36-cp36m-linux_aarch64.whl
Installing collected packages: torch
Successfully installed torch-1.0.0a0+8601b33
dji@manifold2:~/Downloads python3
Python 3.6.8 (default, Oct 9 2019, 14:04:01)
[GCC 5.4.0 20160609] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
File “”, line 1, in
File “/usr/local/lib/python3.6/dist-packages/torch/init.py”, line 84, in
from torch._C import *
ImportError: libcudart.so.10.0: cannot open shared object file: No such file or directory
Error in sys.excepthook:
File “/usr/lib/python3/dist-packages/apport_python_hook.py”, line 63, in apport_excepthook
from apport.fileutils import likely_packaged, get_recent_crashes
File “/usr/lib/python3/dist-packages/apport/init.py”, line 5, in
from apport.report import Report
File “/usr/lib/python3/dist-packages/apport/report.py”, line 30, in
import apport.fileutils
File “/usr/lib/python3/dist-packages/apport/fileutils.py”, line 23, in
from apport.packaging_impl import impl as packaging
File “/usr/lib/python3/dist-packages/apport/packaging_impl.py”, line 23, in
import apt
File “/usr/lib/python3/dist-packages/apt/init.py”, line 23, in
import apt_pkg
ModuleNotFoundError: No module named ‘apt_pkg’
Original exception was:
File “”, line 1, in
xception:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, lin
File “/usr/lib/python3/dist-packages/pip/commands/install.py”
with self._build_session(options) as session:
if options.cache_dir else None
File “/usr/lib/python3.6/posixpath.py”, line 80, in join
a = os.fspath(a)
TypeError: expected str, bytes or os.PathLike object, not int
when i am trying use pip3 to install torvision ,i always met this question,who can help me ?
Hi @530869411, instead of using pip3 to install torchvision, on Jetson you should build it from source as shown under the ‘Installation’ section of this post: PyTorch for Jetson - version 1.8.0 now available
Thank you
