I encountered another problem when compiling the pytorch image the way I did before. The following link is the problem I mentioned earlier.
Step 26/30 : RUN cd /tmp && ./opencv_install.sh ${OPENCV_URL} ${OPENCV_DEB}
---> Running in fafa3bf64538
+ OPENCV_URL=https://nvidia.box.com/shared/static/2hssa5g3v28ozvo3tc3qwxmn78yerca9.gz
+ OPENCV_DEB=OpenCV-4.5.0-aarch64.tar.gz
+ echo 'OPENCV_URL = https://nvidia.box.com/shared/static/2hssa5g3v28ozvo3tc3qwxmn78yerca9.gz'
+ echo 'OPENCV_DEB = OpenCV-4.5.0-aarch64.tar.gz'
++ uname -i
+ ARCH=aarch64
+ echo 'ARCH: aarch64'
ARCH: aarch64
+ apt-get purge -y '*opencv*'
Reading package lists...
Building dependency tree...
Reading state information...
Package 'opencv-doc' is not installed, so not removed
The following packages were automatically installed and are no longer required:
libgtk2.0-0 libgtk2.0-common libtbb2
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
libopencv* libopencv-dev* libopencv-python* libopencv-samples*
nvidia-opencv* nvidia-opencv-dev* opencv-licenses*
0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
After this operation, 83.5 MB disk space will be freed.
(Reading database ... 48117 files and directories currently installed.)
Removing nvidia-opencv-dev (5.0.2-b222) ...
Removing libopencv-dev (4.5.4-8-g3e4c170df4) ...
dpkg: warning: while removing libopencv-dev, directory '/usr/lib/aarch64-linux-gnu/cmake' not empty so not removed
Removing opencv-licenses (4.5.4-8-g3e4c170df4) ...
Removing libopencv-python (4.5.4-8-g3e4c170df4) ...
Removing libopencv-samples (4.5.4-8-g3e4c170df4) ...
Removing nvidia-opencv (5.0.2-b222) ...
Removing libopencv (4.5.4-8-g3e4c170df4) ...
+ mkdir opencv
+ cd opencv
+ wget --quiet --show-progress --progress=bar:force:noscroll --no-check-certificate https://nvidia.box.com/shared/static/2hssa5g3v28ozvo3tc3qwxmn78yerca9.gz -O OpenCV-4.5.0-aarch64.tar.gz
I found this warning in the above log. Do you need to manually delete it?
