Description
running command with pip install pytorch-quantization --extra-index-url https://pypi.ngc.nvidia.com
, but got an error:
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com, https://pypi.ngc.nvidia.com
Collecting pytorch-quantization
Downloading pytorch-quantization-0.0.1.dev5.tar.gz (7.9 kB)
ERROR: Command errored out with exit status 1:
command: /home/yejunxian/anaconda3/envs/torch/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-qw2hkpfc/pytorch-quantization/setup.py'"'"'; __file__='"'"'/tmp/pip-install-qw2hkpfc/pytorch-quantization/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-cdt6c626
cwd: /tmp/pip-install-qw2hkpfc/pytorch-quantization/
Complete output (16 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-qw2hkpfc/pytorch-quantization/setup.py", line 150, in <module>
raise RuntimeError(open("ERROR.txt", "r").read())
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
This package can be installed as:
$ pip install nvidia-pyindex
$ pip install pytorch-quantization
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
