Hello guys
This is my laptop spec: win 10, intel i7 6700 HQ 2.6 ghz, 16gb 2133 mhz cl17 ram, 4 gb nvidia GTX950M, 250gb ssd (60~100 gb available). I need to use ubuntu with virtual OS as well.
I think jetson nano can run Isaac. Can my laptop run too? How can I compare this?
I found out the requirements below;
- CPU: Intel i7-6800K
- GPU: Nvidia GeForce GTX 1080 (minimum), NVIDIA Titan XP (recommended), RTX 2070 (Recommended)
- Memory: 32 GB
- Storage: 512 GB
- OS: Ubuntu 18.04, 64-bit
https://docs.nvidia.com/isaac/isaac_sim/setup.html
How jetson nano run Isaac? This requirements are very high. Is 15 gb virtual space enough to run ISAAC?
My gpu(geforce GTX950M) compute capability is higher than 3.5 so it can run isaac. How about other specs and virtual device?
Thank you
