[Q] cudnnEngine.cpp (87) - Cuda Error in initializeCommonContext:
Dear Everyone.
I transfer the detection inference code to tensorrt.
but i got a error in below:
cudnnEngine.cpp (87) - Cuda Error in initializeCommonContext: 1 (Could not initialize cudnn, please check cudnn installation.)
I trained the caffemodel.
Parsing is success.
but It made error in image inference step.
What is problem?
is it memory problem?
memory is not enough?
Cuda error 1 usually points a device configuration error.
The device function being invoked (usually via cudaLaunchKernel()) was not previously configured via the cudaConfigureCall() function.
Try TRT 5 container nvcr.io/nvidia/tensorrt:18.09-py3 to rule out configuration issues.
If you continue to have this errors, please share a small repro package (containing source, model, dataset) which would help us debug.
I get the same problem. Have you solved it?
