Hi Mat,
I’ll cross-post this to the MPICH2 people, but chances are I’m just missing something simple - I’m trying to compile MPICH2-1.0.2 with PGI 6.0-4, and everything works fine when I use the ‘shm’ [shared memory] channel. However, switching to ‘ssm’ for shared memory on dual processor nodes, the compiler dies very early and leaves me the following message:
PGC-F-0249-#error – *** No atomic memory operation specified to implement busy locks *** (./mpidu_process_locks.h: 234)
PGC/x86-64 Linux/x86-64 6.0-4: compilation aborted
This error comes up due to some code in the file mentioned in the error above - basically, it has some assembler code which is compiled when a #define is true for having GCC. This assembler code is as follows:
#define HAVE_COMPARE_AND_SWAP
static inline char
attribute ((unused))
compare_and_swap (volatile long int *p, long int oldval, long int newval)
char ret;
long int readval;
asm volatile (“lock; cmpxchgq %3, %1; sete %0”
: “=q” (ret), “=m” (*p), “=a” (readval)
: “r” (newval), “m” (*p), “a” (oldval) : “memory”);
return ret;
I don’t know much about how PGI handles in-line assembler, but I briefly tried compiling this section with pgcc -c -Masmkeyword, and it failed, so I deleted the double-underscores surrounding ‘asm’ and ‘volatile’ and tried again, but still no luck:
“Recovery attempted by replacing asm by keyword gasm”
Any ideas how I can compile this while keeping it in a .c source file?
Thanks very much,
- Brian
