I met a problem when I use the Drive PX2.
I developed inference code using TensorRT-4.1.2.
I verified execution on Host PC and Jetson TX2.
And I also verified normal execution on Drive PX2 when I compile the our code in native compile directly.
I tried cross-compile because I want to use camera by driveworks.
But I failed.
Could you tell me how to set the CMakeLists.txt files for cross-compile?
I will verify my CMakeLists.txt and setting enviroments.
So, Can you tell me for setting guide in cross-compile environments?
And I have Second Question.
Second question is a simple.
I don’t want to cross-compile.
But, I still have used cross-compile because I must access the LVDS camera device.
Could you tell me the camera access methods without driveworks and cross-compile?
