Thank you for your response!
I have followed your recommendations and conducted a series of tests. Based on the results, I have concluded that the issue is not related to Q3400_RA, but rather appears to be caused by a problem with the OpenSM version.
Test 1: HDR cluster with OpenSM 5.17.2
I tested a legacy HDR cluster where manual isolation of links functions correctly. This cluster uses OpenSM version 5.17.2. The following configuration settings were verified:
root@srv1:~$ cat /etc/opensm/opensm.conf | grep -E 'hm_unhealthy_ports_checks|hm_ports_health_policy_file|hm_sw_manual_action'
hm_unhealthy_ports_checks TRUE
hm_ports_health_policy_file /etc/opensm/opensm-health-policy.conf
hm_sw_manual_action isolate
It is worth noting that manual drain functionality operates even when the hm_sw_manual_action parameter is set to no_discover, although the reason for this behaviour remains unclear.
The health policy configuration file contains the following entries:
root@srv1:~$ cat /etc/opensm/opensm-health-policy.conf
0x08c0ge0300e4eb01 22 unhealthy
0x08c0me0300eze626 4 unhealthy
Link status verification confirms proper operation:
root@srv1:~$ sudo iblinkinfo | grep Init
2 4[ ] ==( 4X 53.125 Gbps Initialize/ LinkUp)==> 7 22[ ] "sw1" ( )
7 22[ ] ==( 4X 53.125 Gbps Initialize/ LinkUp)==> 2 4[ ] "sw2" ( )
OFED version:
root@srv1~$ ofed_info | head -1
MLNX_OFED_LINUX-23.10-3.2.2.0 (OFED-23.10-3.2.2):
Test 2: Server with OpenSM 5.26.1
On another server within the same cluster, I installed a newer version of DOCA, which includes OpenSM 5.26.1. Despite using an identical configuration, the manual isolation functionality does not work as expected.
OFED version on the second server:
root@srv2:~$ ofed_info | head -1
OFED-internal-26.01-1.0.0:
Configuration settings (identical to Test 1):
root@srv2:~$ cat /etc/opensm/opensm.conf | grep -E 'hm_unhealthy_ports_checks|hm_ports_health_policy_file|hm_sw_manual_action'
Health policy file (identical to Test 1):
root@srv2:~$ cat /etc/opensm/opensm-health-policy.conf
During testing, it was observed that the OpenSM process reads the /etc/opensm/opensm-health-policy.conf file when the command pkill -HUP opensm is executed. However, no operational effect is observed despite successful file reading.
The findings suggest that the issue stems from a defect in OpenSM version 5.26.1. We encountered this problem when working with an XDR switch, as the legacy OpenSM version is incompatible with it. However, it appears that the same issue persists with HDR and NDR generations of InfiniBand when using the newer OpenSM version.
I think this might be a software bug — could NVIDIA run some tests in their lab to help us confirm it? Any help here would be awesome.
