On the smallest file system, use the qemu simulator to install the xfce4 lightweight desktop. The installation command “apt install xfce4” causes problems. The main problems are as follows:
sudo LC_ ALL=C PYTHONHASHSEED=0 chroot Linux_ for_ Tegra/rootfs/ apt -f install
Reading package lists… Done
Building dependency tree
Reading state information… Done
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (2: No such file or directory)
Setting up udisks2 (2.8.4-1ubuntu2) …
Failed to scan devices: No such file or directory
dpkg: error processing package udisks2 (–configure):
installed udisks2 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of gvfs-daemons:
gvfs-daemons depends on udisks2; however:
Package udisks2 is not configured yet.
dpkg: error processing package gvfs-daemons (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of gvfs-backends:
gvfs-backends depends on gvfs-daemons (= 1.44.1-1ubuntu1.1); however:
Package gvfs-daemons is not configured yet.
dpkg: error processing package gvfs-backends (–configure):
Setting up libfprint-2-2:arm64 (1:1.90.2+tod1-0ubuntu1~20.04.10) …
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package libfprint-2-2:arm64 (–configure):
installed libfprint-2-2:arm64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of gvfs:arm64:
gvfs:arm64 depends on gvfs-daemons (<< 1.44.1-1ubuntu1.1.1~); however:
gvfs:arm64 depends on gvfs-daemons (>= 1.44.1-1ubuntu1.1); however:
dpkg: error processing package gvfs:arm64 (–configure):
No apport report written because MaxReports is reached alreadydpkg: dependency problems prevent configuration of fprintd:
fprintd depends on libfprint-2-2 (>= 1:1.90.1); however:
Package libfprint-2-2:arm64 is not configured yet.
dpkg: error processing package fprintd (–configure):
No apport report written because MaxReports is reached alreadydpkg: dependency problems prevent configuration of libpam-fprintd:arm64:
libpam-fprintd:arm64 depends on fprintd (= 1.90.9-1~ubuntu20.04.1); however:
Package fprintd is not configured yet.
dpkg: error processing package libpam-fprintd:arm64 (–configure):
Processing triggers for libc-bin (2.31-0ubuntu9.9) …
Errors were encountered while processing:
udisks2
gvfs-daemons
gvfs-backends
libfprint-2-2:arm64
gvfs:arm64
fprintd
E: Sub-process /usr/bin/dpkg returned an error code (1)
