Hey Guys,
Firstly I wanted to I’m new to the forum so I apologise if I posted in the wrong area.
For the last year I have been running a KVM with QEMU on my Dell M4800, while it works for the most part, there has always been an issue where the GPU won’t jump to the P0 Performance State/Level. I have checked my same configuration on a GTX 680, and the issue appears to not be present with that card.
As a temporary solution that ended up being somewhat permanent, was using NVIDIA Inspector to manually force the default clock speeds on the P5 state at bootup. This solution works quite well, however I’d like to figure out the reason it never hits the P0 state. I took some pictures of both GPU-Z & NVIDIA Inspector which you can access here: [url]http://imgur.com/a/B2Oun[/url]
