I’m trying to use qpDeltaMap in NVENC 5.0.1 SDK samples NvEncoder and NvEncoderLowLatency. According to the SDK qpDeltaMap “specifies the pointer to signed byte array containing QP delta value per MB in raster scan order in the current picture. This QP modifier is applied on top of the QP chosen by rate control.” But I see it hapenning only in the very first frame at some rate control conditions. The rest of the frames do not seem to follow the map at all. How in more details the map is applied to the QPs calculated by the encoder? What needs to be done to get it working? Is it a bug?
Related topics
| How to use qpDeltaMap in SDK8.2.16? | 1 | 1172 | January 23, 2019 | |
| How to use qpDeltaMap, qpDeltaMapSize in Video Codec SDK 10.0 for hevc_nvenc | 1 | 1200 | October 26, 2021 | |
| I'm going to use NvTranscoder to change certain areas of QP. | 1 | 1274 | July 21, 2017 | |
| Does AV1 on Ada architecture support delta qp map? | 0 | 230 | May 2, 2024 | |
| What is the params 'qpDeltaMap' and 'qpDeltaMapSize' | 1 | 825 | March 6, 2019 | |
| Video Encoder qpMap feature for low bitrate applications | 9 | 1821 | October 18, 2021 | |
| Jetson multimedia API sample 01 video_encode | 16 | 523 | July 23, 2024 | |
| Weird behaviour of Jetson h.265 encoder ROI with positive Qpdelta (encoder bug?) | 3 | 560 | September 26, 2023 | |
| SDK 8.1 Emphasis Map | 2 | 1212 | April 19, 2018 | |
| Change Constant QP value without generating IDR | 5 | 1480 | October 12, 2021 |
