QSFP interface available on one Spark but not the other
I’m following the official Connect Two Sparks playbook. At step 2, I can see the interfaces are available as expected on spark-1:
hakeem@spark-1:~$
ibdev2netdev
rocep1s0f0 port 1 ==> enp1s0f0np0 (Up)
rocep1s0f1 port 1 ==> enp1s0f1np1 (Down)
roceP2p1s0f0 port 1 ==> enP2p1s0f0np0 (Up)
roceP2p1s0f1 port 1 ==> enP2p1s0f1np1 (Down)
However, one isn’t available on spark-2:
hakeem@spark-2:~$
ibdev2netdev
Hence when I move to step 4, spark-2 is not recognized.
Additionally, the QSFP interfaces on spark-1 only appear properly when the cables are on the left-most ports of both spark-1 and spark-2. Any other arrangement results in all ports being Down, or otherwise unrecognized.
How can I solve this?
Thank you.
Is there anything in sudo dmesg that would suggest a problem with the device / device driver? (you can compare between the devices since one is working as you expect.)
What is in your related /etc/netplan/* files?
Did you try a reboot?
I used lspci to find the controllers, and found that the driver module mlx5_core wasn’t bound properly. Unplugging and replugging the Spark fixed it.
