As below, nvidia doc does not recommend using flash.sh on orin nx because the memory layout of initrd flashing and flash.sh are different.
However, I will flash only qspi images using flash.sh.
In this case, I would like to ask if it is okay to use flash.sh on orin nx.
(nvme will be flashed separately using dd linux command)
add) The image to be flashed was created using l4t_backup_restore.sh
