[QST] How to enable backtrace in the cgf logging in dw6.0.8.1
Required Info:
  • Software Version
    DRIVE OS 6.0.8.1
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
To Reproduce
when running a cgf app in the version of 6.0.8.1/5.14, we can see the log that shows backtrace disabled
[2023-12-13T03:16:39.87419Z][INFO][tid:0][Launcher.cpp:1198][Launcher] Got signal: 15 (Terminated), si_pid: 10310
[2023-12-13T03:16:39.87521Z][INFO][tid:0][Launcher.cpp:1205][Launcher] This is user exit signal: 15. Wait for gracefully exit done.
***** Backtrace disabled *****
Expected behavior
we can see backtrace when cgf app runs with errors.
Additional context
qsts:
  1. Does the backtrace function in deprecation or disable default?
  2. Is there a way to reenable the backtrace in the cgf5.14?
Dear @lizhensheng,
just checking if this is noticed in DW 5.14 and not in previous version?
Also, may I know if it is part of which log to verify the issue in code repo.
in CGF5.10/DW6.0.6.0, backtrace is enabled and developers can see backtrace in the log file.
But in CGF5.14/DW6.0.8.1, backtrace is disabled.
in launcher.log and in process.log
enable backtrace by yourself using GitHub - bombela/backward-cpp: A beautiful stack trace pretty printer for C++
