Having an issue on migrating a Qt project from RaspberryPi 4 to NVIDIA Jetson Nano . We wanted to migrate our project to Jetson Nano to improve image processing performance.
The qt dependency of our project is >= 5.11 . But Jetson Nano uses Ubuntu 18.04.4 and it has qt5-default package pre-installed in it (in my understanding some system files use it). And this qt5-default packages version is 5.9.5 .
I tried to downgrade my qt dependency, but every change made lead to harder to fix issue.
I tried to upgrade default qt5 version but couldn’t find any similar guidance. The guides/questions already exists are about x86 etc. environment. Couldn’t find any ARM based solution. The qt downloads doesn’t give any buildable for ARM env (or I can’t find them). The official documents only talks about cross-compiling.
What should I do to overcome this issue? Thanks in advance.I’m not an expert of these topics.
I came across this post. Index of /archive in this download archive mentioned in related answer, I tried few downloads but they all look like they’re not fitted for arm-based devices. Am I skipping something.
qt-everywhere-… file has gnuwin32 in it.
