I am using qt-gstreamer 1.2.1 on jetson TX1 with ubuntu 14.04 and Qt 5.2.1.
My application is to preview camera feed with Record / Snapshot / ETH Streaming / Wi-Fi Streaming. any function can be start/stop while preview is running.
I am using tee for different function like record or streaming.
Below is my code for preview with Ethernet Streaming Start/Stop functions.
' queue1 ! nvvideosink
gst-launch-1.0 v4l2src ! caps ! nvvidconv ! caps ! tee ! queue2 ! fakesink
queue 3 ! omxh264enc ! h264parse ! rtph264pay ! udpsink
void gstPipe::init()
m_pipeline = QGst::Pipeline::create();
m_source = QGst::ElementFactory::make("v4l2src", "v4l2src");
m_filter1 = QGst::ElementFactory::make("capsfilter", "capsfilter");
m_convert = QGst::ElementFactory::make("nvvidconv", "videoconvert");
m_filter2 = QGst::ElementFactory::make("capsfilter", "capsfilter1");
m_filter3 = QGst::ElementFactory::make("capsfilter", "capsfilter2");
m_tee = QGst::ElementFactory::make("tee", "tee");
m_enc = QGst::ElementFactory::make("omxh264enc", "omxh264enc");
m_parse = QGst::ElementFactory::make("h264parse", "h264parse");
m_queue1 = QGst::ElementFactory::make("queue", "queue1");
m_queue2 = QGst::ElementFactory::make("queue", "queue2");
m_queue3 = QGst::ElementFactory::make("queue", "queue3");
m_rtppay1 = QGst::ElementFactory::make("rtph264pay", "rtph264pay");
m_udpsink = QGst::ElementFactory::make("udpsink", "udpsink");
m_videoSink = QGst::ElementFactory::make("nvoverlaysink", "sink");
m_fakesink = QGst::ElementFactory::make("fakesink", "fakesink");
m_filter1->setProperty("caps", QGst::Caps::fromString("video/x-raw, width=1920, height=1080, format=UYVY, framerate=60/1"));
m_filter2->setProperty("caps", QGst::Caps::fromString("video/x-raw(memory:NVMM), width=1920, height=1080, format=I420, framerate=60/1"));
m_filter3->setProperty("caps", QGst::Caps::fromString("video/x-h264, stream-format=(string)byte-stream"));
m_videoSink->setProperty("sync", false);
m_videoSink->setProperty("async", false);
m_videoSink->setProperty("overlay-x", 0);
m_videoSink->setProperty("overlay-y", 35);
m_videoSink->setProperty("overlay-w", 1920);
m_videoSink->setProperty("overlay-h", 1080);
m_pipeline->setProperty("video-sink", m_videoSink);
m_videoSink->setProperty("enable-last-sample", true);
m_enc->setProperty("bitrate", 19000000);
m_enc->setProperty("low-latency", 1);
m_enc->setProperty("control-rate", 2);
m_rtppay1->setProperty("mtu", 1400);
m_udpsink->setProperty("port", 8554);
m_udpsink->setProperty("sync", false);
m_udpsink->setProperty("async", false);
m_udpsink->setProperty("host", "127.0.0.1");
m_pipeline->add(m_source, m_filter1, m_convert, m_filter2, m_tee, m_videoSink);
m_pipeline->add(m_queue1, m_queue2);
m_pipeline->add(m_fakesink);
m_source->link(m_filter1);
m_filter1->link(m_convert);
m_convert->link(m_filter2);
m_filter2->link(m_tee);
m_tee->link(m_queue1);
m_queue1->link(m_videoSink);
m_tee->link(m_queue2);
m_queue2->link(m_fakesink);
// Connect to pipeline's bus
QGst::BusPtr bus = m_pipeline->bus();
bus->addSignalWatch();
QGlib::connect(bus, "message", this, &gstPipe::onBusMessage);
bus.clear();
void gstPipe::startETH()
m_pipeline->setState(QGst::StatePaused);
m_pipeline->add(m_queue3, m_enc, m_filter3, m_parse, m_rtppay1, m_udpsink);
m_tee->link(m_queue3);
m_queue3->link(m_enc);
m_enc->link(m_filter3);
m_filter3->link(m_parse);
m_parse->link(m_rtppay1);
m_rtppay1->link(m_udpsink);
m_pipeline->setState(QGst::StatePlaying);
void gstPipe::stopETH()
m_queue3->sendEvent(QGst::EosEvent::create());
m_queue3->setState(QGst::StateNull);
m_enc->setState(QGst::StateNull);
m_filter3->setState(QGst::StateNull);
m_parse->setState(QGst::StateNull);
m_rtppay1->setState(QGst::StateNull);
m_udpsink->setState(QGst::StateNull);
m_tee->unlink(m_queue3);
m_pipeline->remove(m_queue3);
m_pipeline->remove(m_enc);
m_pipeline->remove(m_filter3);
m_pipeline->remove(m_parse);
m_pipeline->remove(m_rtppay1);
m_pipeline->remove(m_udpsink);
This works fine. I can dynamically start/stop Ethernet streaming.
But after several start/stop event some times pipeline hangs on start event. If i used single tee like in posted code it takes 10-15 mins to occur this problem. But if i added multiples tee for all recording/ snapshot and other pipeline hangs after 3-5 min.
Note: This issue occurs only on start/stop event. If i continue to event without start/stop for several hours its work fine.
So what could be the issue?
On some forum i found need to use Pads to add/remove element dynamically.
So Do i need to use pads and its blocking property or something is missing in my code?
