I’m using Quadro CX GPU card.
I just wanted to know that Is Quadro CX supports double data type?.
if you run the devicequery example and you see minor version 3 reported, then it supports double. If you see 1 reported it does not support double
yes, its showing “Minor revison number: 3”.
NOT minor version 3
Also can you tell what is the meaning of :
Major revision number.
Maximum memory pitch.
Clock rate.
concurrent copy and execution.
Major revision number : just what it says. The major revision number. It is 1 for all currently available devices.
Maximum memory pitch : see the memory functions with pitch in the name in the programming guide.
clock rate : the speed of the clock that ticks the GPU.
concurrent copy and execution : tells if you can copy memory from device → host (or the other way) during the runtime of a kernel.
