System:
Machine: Intel Dual Xeon E5-2630
OS: Xubuntu 18.10
GPU: Nvidia K4000 GPU
Monitors: Dual Planar PX212M 1600x1200 Monitors
Problem:
This system has been running fine for years under all past versions of
Xubuntu up through 18.04. The dual monitors are configures without
Xinerama so that separate desktop sessions with separate panels launch
on each screen.
After the recent upgrade to Xubuntu 18.10, the second monitor is not
being recognized. There is a display [b]:0.0[/b], but no active display [b]:0.1[/b].
However, the second monitor is actually active:
* Upon boot it goes from black to a uniform grey
* The mouse can travel onto the second screen (pointer visible)
and keyboard input (e.g., volume keys) are active
* Xscreensaver displays on both monitors when it goes active
I have tried to manually start an xfwm4 window manager on the second
screen, but this is not possible without a defined [b]:0.1[/b] display.
At the following link I have provided a number of screen shots, config
file listings, output from relevant commands and log files to explain
in detail what is (or isn't!) happening. In particular, see notes
under the [b]Log Information[/b] section.
[url]http://smallthoughts.com/xfce/xfce.html[/url]
The above link also contains a link to the nvidia-bug-report.sh log output.
Questions:
What changed between Xubuntu 18.04 and 18.10 that is keeping the OS
from detecting the second screen and configuring it properly and what
can I do to rectify the problem? I will provide additional information
as needed.
Supporting dual monitors with separate window managers seems like a
common set-up, yet I can't find straightforward documentation on
enabling this. Am I missing something?
Suggestions are truly appreciated. Thanks for any help you can offer.
