Quadro MST Max Monitor Amount
Hi, not sure exactly where to post this under, so apologies if it’s the wrong place.
I would like some clarification on the maximum number of display that can be used via MST on a Quadro P4000. I intend to use 6 1920x1080p monitors (MST capable) to display as a single Windows desktop.
On the P4000 data sheet, it states a max simultaneous display of “4 direct, 4 DP 1.4 Multi-Stream”. Does that mean I cannot achieve my setup with this card?
Or, does daisy chaining monitors count as 1? For example, can I connect 3 monitors to the P4000 directly, and daisy chain a second monitor to each of the 3, getting my total of 6. Would this count as 3 DP multistreams, or 6?
