Hey, does the PNY Nvidia Quadro P1000/4GB Mid-3D Grafik, PEX16/3.0, 1SLPHL, 4mDP/DP, 47W graphic card supports G-SYNC?
Thank you in advance.
Hi alexander.horn,
Are you referring to the G-SYNC monitor?
If that’s the case, then the P1000 does support G-SYNC monitor.
If you are referring to the board that controls multi-gpu synchronization (now called Quadro Sync, used to be called G-Sync) then no, that’s a P4000’s and up.
Thanks,
Ryan Park
