I have a Quadro RTX 6000 (Turing, sm_75, 24 GB GDDR6, driver 580.88, CUDA 13.0, Windows 11 23H2) with a confirmed physical GDDR6 defect: multiple stuck-at-0 cells in a localized ~64 KB region at ~1.6 GB VRAM offset, confined to a single GDDR6 chip (chip #16).
Current state:
- ECC enabled (stable, no TDR after
TdrDelay=10/TdrDdiDelay=10registry adjustments) - 8 Double Bit ECC pages already retired (512 KB coverage via organic DBE detection during prior CUDA workloads)
- DPR counter: 8 DBE, 0 SBE, Pending Page Blacklist: No
- Aggregate ECC: 3323+ DRAM Uncorrectable (historical), 112+ DRAM Correctable
- Compute mode: WDDM (Default) — TCC not possible despite multiple attempts
TCC attempt (failed):
nvidia-smi -i 1 -dm 1→ reboot → Code 10 in Device Manager- The Quadro RTX 6000 refuses to initialize in TCC mode on this system
- Reverting to WDDM (
-dm 0) restores normal operation - This blocks
nvidia-smi -r(unsupported under WDDM) and may affect DPR reliability per the v560 documentation
What I attempted for programmatic DPR under WDDM:
0xFFFFFFFFSBE pattern — all-ones write to the bad region. Single stuck-at-0 cell = 1 bit wrong per ECC word → correctable. Result: uncorrectable ECC error — multiple stuck-at-0 cells in the same ECC word produce 2+ bit errors. -
Walking-1 bit pattern (32 passes) — exactly 1 bit written per word → at most 1 bit wrong. Result: bit 0 detects 11 SBE pages, but DPR counter does NOT increment even after 2 passes. Bit 1 write triggers uncorrectable ECC error — the hardware memory scrub reads the region between controlled passes, detects multi-bit errors on unretired pages, and poisons the CUDA context.
devcondisable/enable — resets the driver but does NOT clear ECC error state or allownvidia-smi -r. The scrub resumes immediately and re-poisons the context within seconds. -
nvidia-smi -e 0→ reboot → vram_mapper_detailed (ECC OFF) →nvidia-smi -e 1→ reboot — maps the defect reliably (16 bad 4 KB pages confirmed at chunk 55), but provides no path to retire them.
Questions:
Is Dynamic Page Retirement officially supported on WDDM? The v560 DPR documentation states “Windows TCC platforms” as a supported OS — does this mean DPR retirement mechanics are disabled or unreliable under WDDM, even though ECC error counters are visible in nvidia-smi?
Is there any NVAPI function (documented or internal/OEM) that allows targeting a specific physical VRAM address for forced page retirement, bypassing the organic ECC detection path? Something analogous to
nvmlDeviceGetRetiredPagesbut in the write direction. -
Is the hardware memory scrub configurable or disable-able at any level (driver registry, NVAPI, vbios)? It currently prevents any SBE-driven DPR approach by triggering uncorrectable errors between controlled writes.
For Quadro GPUs that hit Code 10 in TCC, is there any supported WDDM path to achieve a full GPU reset (equivalent to
nvidia-smi -r) without an OS reboot? Thedevcondisable/enable cycle is insufficient.
Any insight into NVAPI internals, WDDM DPR behavior, or alternative retirement paths would be greatly appreciated — even if the answer is “not possible,” that’s valuable data for the community.
Regards
