Quantization Support for PyTorch on Jetson AGX Orin: Issues and Solutions?
I am currently working on a project using the Jetson AGX Orin development board, which runs on an ARM64 architecture. I am using a specific version of PyTorch: 1.12.0a0+2c916ef.nv22.3, provided by NVIDIA.
I encountered an issue with PyTorch quantization support on this platform. When attempting to check available quantization engines using:
print(torch.backends.quantized.supported_engines)
the output is ['None'], indicating no available quantization engines. Additionally, attempting to set the quantization backend to qnnpack resulted in the following error:
RuntimeError: quantized engine QNNPACK is not supported
Given that fbgemm is typically not supported on ARM64, I am wondering:
  1. Does this specific PyTorch version for Jetson AGX Orin support any quantization backend?
  2. Are there any available quantization engines for this platform that I might have missed?
  3. What are the recommended approaches for performing quantization on the Jetson AGX Orin with PyTorch?
I would appreciate any insights or solutions, especially in terms of how to enable or use quantization on the Jetson AGX Orin.
Thank you for your assistance!
1. It looks like quantization is not supported in this release.
But since the package is released for a while, it’s recommended to upgrade to a newer version.
2. TensorRT can do the PTQ for precision int8.
3. Usually, we recommend running the DNN model with TensorRT and applying PTQ for acceleration.
Thanks you for your help.
Since quantization is not supportted in the release 1.12.0a0+2c916ef.nv22.3, can you tell me which release of PyTorch should I fetch for my Jetson AGX Orin?
I need to make sure that the custom distro supports quantization operations.
Best Regards.
Just double-check our AGX Orin with JetPack 6.0 GA.
>>> torch.__version__
'2.4.0a0+07cecf4168.nv24.05'
['qnnpack', 'none']
qnnpack is listed in the PyTorch v2.4. Please give it a check.
