Hi
I recently stumbled on this device
Does anybody know if this will interwork with the Jetson Nano or Xavier NX ?
Regards
Ingemar
Hi
Regards
Ingemar
Hi Ingemar, it doesn’t specify which type of M.2 module it is, so it is difficult to know for sure. The Jetson Nano Developer Kit supports M.2 Key-E. Customized or aftermarket carriers for Nano / Xavier NX can implement the desired type of M.2 interface.
Also from a software perspective, the Linux drivers would need to be provided. Near the bottom it says “USB Driver for Linux /Android”. It doesn’t mention a PCIe driver, although PCIe is called out as a hardware feature of that product. If the drivers only support USB, if desired you may wish to try a less expensive USB dongle first if such a thing exists for 5G.
Thanks for the help, very appreciated
/Ingemar
