leoon
1
Hi guys,
I met a very strange compiling error for my following code:
device funcA();
global funcB(){
funcA()
I call funcB<<<2,64>>>() from main.
And I got following error:
Assertion failure at line 712 of ../../be/cg/NVISA/exp_loadstore.cxx:
Compiler Error in file c:/windows/temp/tmp_00000890-2.i during Code_Expansion phase:
stack pointer nyi: probably an unexpected call or intrinsic
nvopencc ERROR: C:\CUDA\bin/../open64/lib//be.exe returned non-zero status 1
What you think may cause this problem?
Also if I didn’t define funcA as device, what type should I use for it so I can call safelly from funcB()?
Thanks,
Well, you don’t have a semi-colon after the call to funcA; I don’t know if that’s a copy-paste error or a mistake in the actual code though.
leoon
3
Thanks eelsen, just figured out the problem.
It’s because I use a memset() function in device funcA(). It gives out a warning which I didn’t notice. That’s the reason of the error though.
