hello!, I have some Question about AGX Xavier PCIE Reset.
I inserted the LTE Module into the AGX Xavier KEY-E (M.2) Connector and used it.
LTE Module is M.2 KEY-E Type Form-factor but signal I/F is USB 2.0.
If the PCIE Reset signal of the KEY-E M.2 Connector is measured with an oscilloscope, it continues to show as Low and the device is not recognized.
Question
- We inquire about the conditions under which AGX Xavier PCIE Reset Signal becomes HIGH.
- If PCIE TX/RX signal is not connected between AGX Xavier and PCIE Device, does Xavier not output PCIE Reset signal as HIGH?
Thank you for your reply.
