**• Hardware Platform (Jetson / GPU) : Jetson Orin **
**• DeepStream Version : 6.3 ** • JetPack Version (valid for Jetson only) : 5.1.3 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) : questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Hello, I want to see the real-time output of the deepstream-app’s like bbox_info, tracker_info, but there is no mention at the deepstream reference.
Can you give me any advice or command to see this info?
The command I used : 'deepstream-app -c ./source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8’
We already have some information that can be dumped to the file. You can set the gie-kitti-output-dir property in the config file.
If you want additional information, you can add it to our source code yourself.
You can refer to our Guide Application group to configure the corresponding parameters to get the information you want.
You can also refer to our source code directly.
