Question about FDD RU Support
We are planning to integrate the Aerial DU with some O-RUs. Could you please confirm if your DU supports the FDD RU type?
Thank you.
Hi @nguyen_thanhtam ,
Welcome to the Aerial Forum!
We currently only support TDD configuration.
For future reference, what is the FDD configuration you are looking for?
Thank you.
As many places use FDD O-RU for 5G, we plan to integrate FDD O-RU with Aerial DU. The FDD O-RU has following specifications:
  • 4T4R, band 3: UL: 1.71-1.785 GHz; DL: 1.805-1.88 GHz
  • IBW: 75 MHz
  • NR carrier: 10/15/20/40/45/50 MHz
  • Sync: IEEE 1588PTPv2, SyncE
    Thank you.
