Hi all,
I am using Optix 6.0, with CUDA 10.0.130, Ubuntu 18.04 and gcc 7.3.0, driver 418.43.
I am not sure about the use of callable programs vs plain functions. That is, up to now, I have been using callable programs when I needed some function. I have tried changing some of them to functions.
For instance, I have declarations like the following:
__forceinline__ __device__ void traceSomeRay(RayPayload& rayPayload) {
rtTrace(root, ray, rayPayload);
__forceinline__ __device__ void traceAnotherRayType(RayPayload& rayPayload) {
Something similar is done in the advanced samples so I do not see any problem. I can put those definitions in a traceFunctions.h file and include and use them with different ray generation programs.
I can also include the file in a closest hit program and do recursive tracing.
Reading the documentation, it suggests using callable programs for “changing of the target of a function call at run time”, which I do not really do. But it also says:
“Also, if you have a function that is invoked from many different places in your OptiX node graph, making it an RT_CALLABLE_PROGRAM can reduce code replication and compile time, and potentially improve run time through increased warp utilization.”
So the question is: is it better to use callable programs rather than using the functions like that? Even if I use them to do recursive tracing?
I am not sure if I am messing with something. I have tested both approaches in a small scene and I cannot see any apparent problem. I do not see any performance difference either.
Thanks for your advice.
