Question about fuse and flashing
My team is working on a project involving the Jetson Orin NX and have encountered a few technical questions related to the Boot Security Info fuse, the fusing process, and flashing the EKS partition. I would greatly appreciate your expertise in clarifying these points to help streamline our development and manufacturing process. Below are my questions, based on observations and the latest “Jetson Orin Fuse Specification” (DA-10877-001_v1.4 | February 2025).
  1. Understanding the Boot Security Info Fuse Value “000001e0”
According to the Jetson Orin Fuse Specification, the FUSE_BOOT_SECURITY_INFO_0 register has specific bit mappings, as outlined below:
FUSE_BOOT_SECURITY_INFO_0 Boot Security Info
Bits interpreted by boot software with the following mapping:
Bits [2:0] mapped to Secure Boot Authentication Scheme, where:
  000b: SHA2-512 Hash (not recommended)
  001b: 3072-bit RSA
  010b: ECDSA P-256 Curve
  011b: ECDSA P-521 Curve
  100b: Ed25519
  101b: XMSS – no Pre Hashing
Bit [3] secure boot encryption scheme (SBK) enable
Bits [8:4] Not available and may not be logic 0 by default
Bit [9] ODM Key Valid
Bit [11] OEM DICE1 Feature enable
Bit [13] FMC DICE Feature enable
Bits not listed are reserved.
I have observed that many Jetson Orin NX boards have a pre-fused Boot Security Info value of 0x000001e0. Based on the documentation, I understand that bits [8:4] are not available and may not be logic 0 by default, which seems to align with this value. Could you please clarify the following:
  • What does the value 0x000001e0 specifically indicate in this context, particularly with respect to bits [8:4]?
  • Why is this value observed on only some boards? Is it possible for bits [8:4] to have a different default value on other boards?
  1. Fusing Jetson Orin NX Without Initial Flashing
I am attempting to fuse a Jetson Orin NX using the following command:
./odmfuse.sh -i 0x23 -X $XML_FILE jetson-orin-nano-devkit
However, I encounter an error when running this command on brand-new Jetson Orin NX boards straight out of the box. This issue has been consistent across multiple devices from the same batch. As a workaround, I have found that flashing the Jetson first, then fusing it, and finally flashing again with the appropriate eks_signed.img file resolves the issue. However, this additional flashing step is not ideal for mass manufacturing due to the extra time and complexity it introduces.
In contrast, when working with the Jetson Xavier NX, I was able to fuse devices immediately without an initial flash. Could you please provide insight into:
  • Why is an initial flash required before fusing on the Jetson Orin NX?
  • Is there a way to fuse a brand-new Jetson Orin NX without performing an initial flash, to optimize the manufacturing process?
  1. Flashing Only the EKS Partition for Secure Boot
This question is related to the fusing process described above. Given that my current workflow for enabling Secure Boot on the Jetson Orin NX involves: (1) flashing the device to enable fusing, (2) fusing the device, and (3) flashing again with the eks_signed.img file, I am looking to optimize step (3) to reduce manufacturing time. Specifically:
  • Is it possible to flash only the EKS partition (e.g., eks_signed.img) to the QSPI in step (3), rather than reflashing the entire system?
  • If so, could you provide guidance or a sample command to flash only the EKS partition while ensuring compatibility with Secure Boot?
hello yanlin.li,
>> Q1
the fuse value for boot_security_info was burned by manufacturing to 0x1E0. it’s around in the beginning of 2025.
Bits [8:4]: they are used for fuse encryption. however, L4T does not support this feature.
you may just consider they’re “Reserved”.
>> Q2
I’m not aware of that. is it due to a brand-new Jetson Orin NX boards did not program QSPI?
could you please try to flash QSPI only for verification,
for instance,
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 jetson-orin-nano-devkit internal
>> Q3
unfortunately, partition update (i.e. -k A_eks) has disabled once you have secureboot enabled.
Thank you @JerryChang
