I’m using docker on Nvidia dgpu. I want to output stream through RTSP and I see there is an example from deepstream python. But that example set up everything in the code. Is it possible to use only the config file? Is there anything I need in the code when using the config file for RTSP (like creating an output sink)? Anything should be noticed when using docker?
The docs from Nvidia seem not enough and leave the user with a lot of confusion/questions.
