hi nvidia,
I’m using jp6.0 (agx orin) and found that menuconfig so many configurations are not enabled by default, such as usb-wifi, etc., but before 5.1.2 these were enabled by default.
What is the reason for turning some modules and drivers off by default on jp6.0?
Jetpack6.0 is more aligned with upstream kernel. If you need some specific driver, you need to enable it by yourself.
thanks,
