Hi:
I recently met an issue when playing with acceleration structures.Hope someone could give me a hand.
In my scene structure it’s just one top_group(Trbvh)->some xfroms-> GeometryGroup(Trbvh)->Geometry Instance->geometry
It works fine.
Now i assign a invisible material to one geometry instance(a material with anyhit just rtIgnoreIntersection())
it still works fine and that object is invisible.
Here comes the issue.
When I apply a scale to the object’s xform and scale it down to 0.99 on x,y,z. That object change to black color instead of invisible.
But if i change the top_group structure to NoAccel. The scaled down object looks invisible again which is what I want.
So far I only found scale down will affect the invisible object. Scale up seems ok. rotation and translation is ok.
my question:
1:is this a bug for trbvh structure? (i also tried Bvh the same issue.)
2:Since NoAccel works fine but it affect performance what’s the better options here?
thanks you
If it’s the same error as I think, then it’s not happening in a newer internal version of that code path in OptiX anymore and the next major release should pick it up. I cannot comment on release dates though.
