**• Hardware Platform:GPU
**• DeepStream Version: 6.1.1
**• TensorRT Version: 8.4.3
**• NVIDIA GPU Driver Version: 515
**• Issue Type: questions
Hi, I want to ask about nvdsosd plugin process mode.
I set the plugin with process mode MODE_GPU, but as below profiling, it seems to work in CPU mode.
I also confuse about the enum comments in nvll_osd_struct.h
* Defines modes used to overlay boxes and text.
typedef enum {
MODE_CPU, /**< Specifies using the CPU for OSD processing.
Works with RGBA data only */
MODE_GPU, /**< Specifies using the GPU for OSD processing.
Currently not implemented. */
MODE_HW /**< Specifies the NVIDIA hardware engine
for rectangle drawing and masking.
This mode works with both YUV and RGB data.
It does not consider alpha parameter.
Not applicable to drawing text. */
} NvOSD_Mode;
So, just to confirm, is DeepStream 6.1.1 support OSD processing on GPU yet?
