Do the USB pins (USB0_EN_OC#, USB0_VBUS_DET, and USB0_OTG_ID) effect only USB0_D±?
For example, USB0_EN_OC# becomes LOW, then USB0_D± would be stopped but anyother data lines
(USB1_D±,USB2_D±, and USB_SS) can be worked?
Does the USB1_EN_OC# effect only USB1_D±?
This question is simlar to Q1.
USB1_EN_OC# effect only USB1?
Hi, USBx_EN_OC# is to enable power supply of vbus when USB port of Jetson is set as host. USBx_VBUS_DET is to report to Jetson that there is a USB device plug in. USBx_OTG_ID is to tell Jetson that the port is set to host or device. These signals’ behavior is the result not the cause of USB enumeration/detection.
I see that USB0_VBUS_DET is to report to the Jetson that there is a USB device plugged in, however, I dont see a way to tell the jetson that there is a device plugged into USB1, as there seems to be no USB1_VBUS_DET pin on the jetson. How should I handle this?
